counter config.vi
I'm just a newcomer in the labview-world and so a little bit helpless sometimes.
I have some questions, which stopp the going-on in my project.
1)
When I start different examples (which I need to understand LABVIEW and to realize a connection with my PCI 6602) so the search of "config group.vi" or "counter Control.vi" and a lot of others subVi's is unsuccesfull. How can I get these subVi's, exist a possibiliity to download these subVi's or what can I do else?
2)
I have a PCI 6602 card ( connected with a SCB-68 ). Is it possible to customize my amplitude of a square signal over this card (perhaps a second channel). What are the essentiell functions to send a square signal over a DAQmx task/channel? Can I use the Analysis function Simulate signal (Square)?
THANX A LOT FOR YOUR HELP!!!!:mansad:
(2,843 Views)
Just to point you in the 'right direction'
*To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Thanks to 'grand master wizard tst' the above is his 'macro' which I have cut and pasted.
PS tst ( hope you are not offended by salutation )
chow
xseadog
(2,839 Views)
Hi again
just did a quick hit using: 'pcI 6602 config group vi'  in discussion forum.
Possible  examples there.
No doubt adjusting search string will bring further examples/ solutions
Happy searching
chow
xseadog
(2,836 Views)
Not offended.
My suggestion is that you use this yourself as a macro, and if you know of any better tutorials, then link to them.
(oops, I already do that automatically...) Smiley Very Happy
___________________
Try to take over the world!
(2,834 Views)
