counter of days
hi,
I want to make a counter that counts the days in a month
example:  start at first january
                counts 31 days and jumps to first of february
                then counts 28 days and jumps to the first of march
I want to couple 2 integers to the month (max and min temp)
thanks in advance
(3,502 Views)
Hello suske,
what do you want exactly:
Should the vi know the number of days per month? Or do you just want to have the number of days between 2 dates? Or do you need just a date string like '1. Feb. 2006'?
Anyway, there are functions in the time&dialog palette to do this: "Date/Time to seconds" and "Seconds to Date/Time". You can setup your own date in a date record and manipulate it...
(3,492 Views)
Hi Suske,
Can you use the VI in the picture. From the timestamp the day, month and year number is displayed.
(3,487 Views)
thanks for the reply
in my front panel there's a text box with the month and one with the days
the day in the textbox must not the same as the present day
I have a timer so one day has a lengt of  5 seconds
Its for my project for school and I need a "little" bit help
thanks
(3,483 Views)
Thanks for the reply KC
but the timestamp is not an option.
(3,481 Views)
Perhaps if you show us the VI and tells us what the result should be we can help, because I don't understand want you exactly want.
(3,477 Views)
