counter out ctr0 channel for stepper motor driver pulse status in mid of start task
I'll respond here to a new thread you created for the same general issue.
@DMic wrote:
is it possible to read the pulses which are out from the counter out of the same card 6229 using AI or DI channels which is best option.
If you want a "live monitor" of step counts, I think your best option is probably either AO or DO, whichever is less likely to be needed for other things.  Here's how it'd work:
1. Configure the output task to use the counter's output as it's sample clock.  The 'source' input to DAQmx Timing can be set to something like "/Dev1/Ctr0InternalOutput".   (On a DAQmx terminal constant, right-click and select "I/O Name Filtering" from the menu.  Then check "Include Advanced Terminals" in the popup.)   Make it a continuous task.
2. Write meaningless data to the task with DAQmx Write.  Something like all 0.0 V values for AO or all low state values for DO.
3. Start this task *before* starting the CO pulse generating task.
4. You can query this AO / DO task for "Total Samples Per Channel Generated" using a DAQmx Write property node.  That # will be your step count.
5. When the CO pulse task is done, stop the AO / DO task too.
-Kevin P
Message 11 of 11
(406 Views)
