counter pxi-6221 - some elemtary qestions
I've made the needed change from the regular Start Trigger to the special trigger needed for counter input measurements -- the "Arm Start" trigger.  It's only available through the DAQmx Trigger property node as shown.  I'm assuming that your task is configured properly otherwise.
-Kevin P.
Message Edited by Kevin Price on 11-25-2006 07:58 AM
Message 11 of 15
(1,129 Views)
thank you very much. Now there is now error occuring anymore. But now there is no triggering. As soon as i start the vi the measurement starts. The start trigger node says always "ok". Why? Even if there is physically nothing connected to this port.
Jens
Message 12 of 15
(1,110 Views)
Hi Kevin,
now it works. Now i can trigger one conuter with one TTL signal! I am so happy! Smiley Happy
There was one connection missing in your picture.
Thanks!
regards
Jens
Message 13 of 15
(1,106 Views)
And it even works with two triggers!
Thank you very much!!!
Jens
Message 14 of 15
(1,106 Views)
Sorry about the missing part -- glad you were able to figure it out.  For anyone reading along without LV 8.0 or higher, the
missing item was the property ArmStart.TriggerType = Digital Edge.  That's the one that really enables the triggering.
-Kevin P.
Message 15 of 15
(1,094 Views)
