couple of the coloumns of two arrays
Hi, Hope all are well inspite of the pandemic COVID 19. However, I am facing a problem during building up a code in labview.
I have two arrays, array1 and array2 as in my code. I want to couple array1 with array2 so that 1st coloumn of array2 will be just after the 1st coloumn of array1, then 2nd coloumn of array1 then second column of array2 just like (col1)_array1>>(col1)_aray2>>(col2)_array1>>(col2)_aray2>>(col3)_array1>>(col3)_aray2.. I have tried to use "Build Array" to build up this but for that case all the coloumns of array1 appears first then all the columns of array2.
How can I solve this?
Thanks in advance.
(2,257 Views)
(2,228 Views)
Thank you for your prompt help. Yes, this is waht I wanted.
(2,224 Views)
