covert string to number
Hi all
I have question please
I have string as 31233455477687643254 its 20 digit number . I want to convert this string to number and i want to displayed it as it shows
what i mean
The string is 31233455477687643254 and I want to convert it to number shown as same digit
Can it be done ?
Thanks alot
(2,833 Views)
Hi Elyan,
this number exceeds the range of an U64 number (which only allows 18446744073709551615 max).
It also exceeds the precision of a DBL or EXT number so you will lose some digits:
(2,824 Views)
It already is a number, right. I assume you want to convert it to a numeric datatype. There is no LabVIEW datatype that can hold this number and keep all significant digits. You need to craft your own datatype. (e.g. a cluster of two U32). Then you need to write all needed basic operations (formatting, scanning, add, multiply, etc. from scratch).
(2,821 Views)
