cpu 100 percent in executable
I've developed an application that uses UDP messaging to communicate with a cRIO 9022.
When running the application on the development system, it sends and receives messages, no problem.
However, when I build an executable, and try to deploy it on a clean system, (no prior LabView RTE), the application seems to run up to 100% when trying to run the UPD messaging.
Has anyone had anything remotely similar ?
(2,900 Views)
Hi DeOdderKeith,
That is odd, I have never seen this. Is it running a while loop at full speed?
Flash
(2,867 Views)
