crash labview 2014
Good Day
I got an error when running VI( picoscope 5000EaxampleBlock vi)  by using LabVIEW2014( LabVIEW crash ) This also been done by using a PIcoscope 5000 series meter
Exception: Access violation (0xC0000005) at EIP=0x0000000100000000
version: 14.0 (64-bit)
attached also Lv log and SubVI.
Can anybody advice on this matter..
Best Regard
AhmadTarmimi
Universiti Teknologi Malaysia
(4,831 Views)
Accepted by topic author ahmadtarmimikassim
Without seeing the your scope drivers, this is just speculation...
Any time I have seen a crash like that from drivers it has been a call to a DLL that caused the problem. It may be that you are running 64 bit LV trying to call a 32 bit driver DLL.
(4,786 Views)
Hi Bowen
Thank for the reply
the DLL file already use a 64 bit( download from picoscope website) but the VI i think in 32 bit version...
is there any method that chage VI from 32 bit version to 64 bit...
Best regards
Tarmimi
(4,752 Views)
You install LV2014 x64.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,661 Views)
/Y
Yes, then if you need to have a 32-bit version, have a dev statsion with LV 32-bit and the 32-bit dll.  The VIs are just the source code and will open up just fine in either LV version.
The only issue is that LV 64-bit might not have the tool kits that you need.
Bill
CLD
(Mid-Level minion.)
(4,652 Views)
