crash while saving
I am facing this problem with LV2010. I am using windows 7 32-bit.
Please refer to my attached vis. 6dof_v10 is the main vi while TCP init_stop and TCP start are both sub vis inside 6dof_v10. I have extracted much of the algorithms inside the control and simulation loop due to sensitivity of the details.
If you open the main vi, you will notice that the run icon is in grey as there is an unwired terminal. Once you wire up that terminal and the icon turns white, when you try to save it, it will crash and auto shutdown.
I also notice that the problem is not unique doesnt lies with just that particular terminal. eg. i wire up that terminal and then remove another wiring, so that the run icon is in grey, i am able to save it with no problem at all.
I am not sure what is the problem here. If you have experienced that before, please advise how i can resolve this problem. Thank you.
(3,305 Views)
anyone can offer any suggestion?
(3,271 Views)
Hi Guys, any help?
(3,243 Views)
