creat a time indicater
I want to creat a timer to indicate my VI running time since I click the "start" bottun. the timer may be like following format.
HH : Min: SEC.
120: 51: 12
this data means my VI has run 120 hours and 51 minitues...
Any help is appreciate.
(3,459 Views)
You can use the timestamp functions to do so.
Check the Time & Dialog pallette to see what fits your requirement.
- Partha ( CLD until Oct 2027 🙂 )
(3,454 Views)
Thank you ,
I checked this pallete but I did not find the solution.
Can you make a simple sample for me?
Thanks.
(3,452 Views)
You just need to use the elapsed time function. Set the auto reset to false and then wire up a string indicator to the Elapsed Time Text output or a numeric indicator to the Elapsed Time (s) output. If you use a numeric indicator, set the display format to absolute time.
Message Edited by Dennis Knutson on 09-24-2007 07:43 AM
(3,428 Views)
Thanks a lot.
(3,408 Views)
