create a dll without Visual Studio
Back Again!
I have run through Using External Code Manual in order to build a shared library or DLL from C Code.
3 steps are described to build the DLL with the third one being "Build a Library Project in an external IDE" which i haven't got.
And I know that the Application Builder can be used to build a DLL but from VIs and not C code.
So, Are there any solutions to re-use my C code in LV without any compiler?
Christophe
Message 1 of 11
(8,884 Views)
I understand not wanting to drop the $$ (or is it $$$) for VS. Have you considered the Express versions from MSoft, they won't cost you a dime.
Message 2 of 11
(8,880 Views)
Haven't tried it myself, but there's also gcc through MinGW. Although gcc is usually used on the Linux side.
Message 3 of 11
(8,873 Views)
What do you mean?
Thanks for your 2 suggestions...I will investigate them! I wanted to be sure not to miss something about DLLs and their creation.
Christophe
Message 4 of 11
(8,851 Views)
In most cases(but not all) the best solution is to use native Labview.   What kind function do you want to implement in C++
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 5 of 11
(8,836 Views)
My goal is to re-use a C++ code that I made a few years ago resampling .jpeg images given an algorithm (IMAQ Resample doesn't exactly suit to my needs). So I was looking for solutions not to rewrite evrything under the LV environment. And I am not familiar with DLLs with LV...
I downloaded VS 2010 express version and called my first DLL in LabVIEW that makes the average of numbers (http://zone.ni.com/devzone/cda/tut/p/id/4877). I now need to make the same thing but with my C++ code!
Native labview :  what's this?
kind of function : void blablabla Smiley Happy Are you asking for the prototype?
Message 6 of 11
(8,820 Views)
No but is is well know fact that then C programmers are retrained to Labview. Their programming style is often far from good Labview practice.  And many times problems are solved in a strange manner. A good example is abusing globals and locals as they think they are just pointers.  Also cheating using DLLs for problems that easily could be done in Labview is not uncommon.
Message 7 of 11
(8,811 Views)
A proper native C++ function should execute significantly faster than an equivalent function written using the LabVIEW realtime engine.  Though, we're probably talking about entirely different levels of code as I do this with image processing and I may just not be very good at writing optimized LabVIEW code.
Message 8 of 11
(8,796 Views)
Of course. I am talking about problems that easily can be transferred to Labview code. Labview as a software development tool. Has its pro and cons. Labview is a good approach to solve some problems, and not so good in others.
What I was referring to was more like problem solving on this level. They have not used a DLL but I think you will see my point.
Message 9 of 11
(8,787 Views)
I use Code::Blocks for writing C code. I've used it to write dll's that I call with labview so I know that works. I'd recommend getting the one with mingw to make things easier.
Message 10 of 11
(8,772 Views)
