create a labview test in testStand
Hi!
I have an issue. I want to create a new labwiew step with testStand.So I:
*configure adaptaters:in the window I select:labview then configure, in the new window I select development system and allow only new templates and ok.
*insert a numeric limit test step.
*right click the new step and select Specify module.
and here I have an error message:
Unable to launch the labview application activeX automation server
error code -18001,an error occured accessing the labview activeX automation server.
If you know what are my errors tell me please!
thanks
sole
ps: I'm sorry I have posted this message in the section testStand before and it wasn't the good place
(2,968 Views)
Please see you answer at the following post: http://forums.ni.com/ni/board/message?board.id=4170&message.id=2705.
(2,954 Views)
