create a link in front panel and property node option
hello,
how to create a link in the main vi? the idea is like attach picture. I do try using the property node option which when i click
the button it will popup the page or example like graph i want to display. But this function is based on visible/invisible the display
as i explore it. is there any smart or better way to do this link technique?
Zull
(3,199 Views)
I'm not sure I completely understood, but if I did, you can simply use a tab control to do what you want, and simply set the tab page that is visible by writing to the tab control's value either via a local variable (down all you local variable haters) or a property node. The button can be made to appear over all tabs by moving it onto to the tab control using the arrow keys (NOT the mouse).
(3,186 Views)
Thanks for the review. I get it the idea to use tab control and the property node.
Zull
(3,133 Views)
