create a logger from measure-code
I have a main-code for conductivity measuring. (AnalogDevice- Evaluation CN-0349-Kit)
Its very good and cheap solution for a "conductivity-meter".
I would like the measuring beginn every minute (for example) automaticall and consulution the program should also save the log.
But I do not get get the adjustment.
Its a adjustment a major programming task?
My "solutions"(try) with a simple counter and a puls-generator on the "measure-button" were unsuccessful.
Can someone help me? (with tips/tricks/solutions, or ,or, or)
Best regards
Christian D.
(4,507 Views)
Oh, my, you are trying to rewrite "Demo Software" provided by a vendor who may or may not know how to write good LabVIEW code, and you want to try to fix it?  And you are not a LabVIEW expert (or, at least, up to CLAD or CLD level)?
You may consider some advice I've been know to give when confronted with undocumented, difficult-to-read code -- "Start Over".  [I do realize this is probably not practical in your case, so here's a different piece of advice -- Find (or Hire) a LabVIEW Guru].
Bob Schor
(4,469 Views)
Hello Bob...,
thanks for your answer.
I was hopping a "auto-mesure" is easy to implement in this software.
I thought a automaticly start (every minute) is no big deal... but I have already noticed the contary... 😞
I think it's ever good that you say difficult-to-read code...I thought just me was going there.
short info  about the program:
- with this program and corresponding modules can measure conductivity
(4,461 Views)
I believe its possible without guru-crafts... ;:)
but my experience not enough... 😞
actuate automatic or periodic  the measure-button:
If I select property "Value Signal" that then is the push automatic...or?
I get this only with ERROR-Massage (not wired...)
It should be possible??!! 😕
Can someone help me or try the variant ?
greetings
Christian
(4,434 Views)
Crosspost in German LabVIEWForum…
(4,426 Views)
