create a variable to store data
hi all
is there any way to create a variable (memory allocation) to store temporary data?
for my case i am using a while loop and i want to store a result that the next iteration can make use of.
(3,081 Views)
Hello leongchuan:
You can use a shift register, a feedback node, or a local variable if you want. Depending on your application.
Each has pros and cons...
(3,078 Views)
In the specific case of a while loop a shift register or a feedback node would be what you want. Either click on the side of the loop border and select Add Shift Register, or drop a feedback node (from the structures palette) in the loop. They do exactly wat you want.
___________________
Try to take over the world!
(3,073 Views)
