create an order spectrum from scratch (i.e. getting a position-based fft from even-time-sampled data)
Hello Folks,
WHAT THE QUESTION PERTAINS TO:
I am performing time-based sampling on 2 parameters of a system: rotary position and vibration (accelerometer in units of g).  I desire to take a position-based fft to create a magnitude-phase order spectrum of velocity in in/s.  To do this I must perform the following two operations:
1. integrate (and scale) the vibration signal from g to in/s (SVT Integration.vi)
2. resample the even-time sampled vibration signal to an even-angle sampled signal (ma-resample unevenly sampled input (linear interpolation).vi)
THE QUESTION:
Which order should the operations be performed in, integrate then resample or vice versa?  I didn't think that the order would matter, but using the same set of data, the results are drastically different.
NI ORDER ANALYSIS TOOLSET 2.0:
I have the NI Order Analysis Toolset 2.0, but I haven't been able to figure out how to get the speed profile generation vis to work with DAQmx (via pxi-6602) quadrature encoder position signals.  Furthermore, it appears that I have to specify every order that I'm interested in looking at, which I don't really know at this point (I want to see all available orders) so I just decided to do my own position-based fft to get an order spectrum.
Any help is greatly appreciated.
Chris
(3,161 Views)
Hi Chassan,
I know the SVT Integration will make certain assumptions about your input signal, so order could be a factor. Drastically different? Did you look at the Sound and Vibration Examples. How are you resampling your data? Can you post your VI and data?
Matt
(3,136 Views)
Hi Mr. F,
Thanks for the reply.  I think I can post some data and vis, but it may take a little while as I have had to change my focus to a higher priority task.
Best Regards,
Chris
(3,119 Views)
Accepted by topic author chassan
The proper order is to integrate the time domain first - creating a velocity channel.  Now you have a new channel of data.  Typically I would put this into the same waveform array along with the acceleration time waveforms.
Then resample your accleration and/or your velocity waveforms, and then you can compute the order spectrum.
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(3,105 Views)
Hello Preston,
Thanks for the good information.  That was the conclusion that I came to; that is, integrating an even-time sampled acceleration using time as the variable of integration would yield an even-time sampled velocity whereas integrating an even-angle sampled accleration using rotary position as the variable of integration would yield something, but I'm not sure what.
Best Regards and thanks again (Preston and Mr. F.).
Chris
(3,097 Views)
