create array of 2D
a need create a array of 2D entering whith one element whit 2 "struct for" indexed. How to create?
(3,615 Views)
Hi chiliwilyx,
use the initialize array function or create an array constant. You should also visit the free courses at ni.com.
Mike
(3,613 Views)
Hi MikeS81, I understand you but after create the array i need sing in for exmple one element into of this array. I think than to some block entering parameters like 'row, col and the element'. You understanding?
(3,610 Views)
Hi chiliwilyx,
you want to "sing"? I can hear music...
Back to topic: have you looked at the array palette? There's a replace function to - ahem - replace array elements given by their indices :smileyvery-happy:
(3,605 Views)
jajajaj my inglish is very bad jajaja anyway
(3,600 Views)
  1. place an empty array container on the front panel.
  2. Drop a numeric control inside it.
  3. Resize the "index display" downward so it shows two dimensions. (or right-click it...add dimension).
(3,586 Views)
