create captions automatically?
can I create captions automatically?
Background: I'm trying to switch between "label" and "caption" in a program by using the property node "caption->visible". To be able to do that I have to right-click each label and activate "caption-visible" vor every control/indicator I create. I cannot do that in run-mode if that has not been done in edit-mode once. (Otherwise you get error 1320)
So the best way to solve this would be a program that opens my "HMI-program" in edit mode and sets this property. Is that possible? My HMI-program has more than 200 controls.
Thanks!!
-DB
(2,979 Views)
Accepted by topic author bef
Thanks!!
Yes just open the VI and get a ref to the FP and traverse the FP looking for all controls and indicators.
Ben
(2,972 Views)
Thanks Ben,
wow, that was fast!
Thanks for the hint. That was easy and worked super!
-DB
(2,962 Views)
