create color table from a jpeg
OK, here's the (seemingly?) correct way to read LUT files into a 256 element color map (LabVIEW 2014).
See if it works for you. 😄
Message 11 of 13
(2,651 Views)
Hi Christian,
thanks for correcting me.
It was a (kind of) copy&paste error: I looked at those LUT files using a hex editor presenting byte offsets in hexadecimal. Ofcourse you need to use 0x100=0d256 instead of 0d100 when reshaping the array.
Background: Several years ago I worked with an ultrasonic microscope. The software for that scope used similar (or even the same) color files for generating images - back then I also used my own LabVIEW routine to convert measurement results to nice(r) images and also had to load such LUT files. Back then those files also had a filesize of 768 bytes (768 = 3*256 = 256 * RGB), so all you have to do when loading them is to recognize the order the bytes are written in such files (either "RGB, RGB, RGB…" or "RRR…, GGG…, BBB…").
Message 12 of 13
(2,617 Views)
In summary:
  • The *.lut files sometimes have a variable size header that I did no investigate further. (e.g. some are 800bytes)
  • We need to get the last 768 bytes from the file and discard the beginning if the file ls longer than that.
  • The color arrangement is not [RGBRGBRGB...RGBRGBRGB] but [RRR....RRRGGG...GGGBBB...BBBB], each stretch is 256 bytes.
In any case, this website has a nice collection of color tables and I might actually use some of those. Great find. Thanks!
Message 13 of 13
(2,606 Views)
