create control & indicator tricks
hi
can anyone tell me how to create the variable "message" in this block diagram ?
thank you
(2,970 Views)
That's how local variables used to look. Right-click on the messages indicator Create > Local Variable.
(2,947 Views)
I find it easiest to use the front panel.  Right-click on the "message" control and select Create->Local Variable.  You can also use the control's terminal.
(2,945 Views)
