create folder error 7
Running LV2010 and I'm having trouble with creating some folders on my c: drive.  Attached is a pic of the code.  It thows and error 7 everytime it runs and it will not create the folders.  Any ideas?  Thanks.
(5,013 Views)
Looks like you are creating the folder on the root. Are you running Win Vista/7/8? UAC (User Account Control) can disable some programs from messing with the root directories. Try right-clicking LabVIEW and running as Administrator.
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
(5,007 Views)
--> Close LabVIEW.
--> Right clicking LabVIEW shortcut and select "Run as administrator"
--> Now try running the same VI...
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(5,004 Views)
If the file or directory does not exist, you will get error code 7 out of the File/Directory Info VI.  What I usually do for creating a folder is to just use Create Folder and ignore the error you get if it already exists (error code 10).
(4,999 Views)
Ok, I think I'm all set.  I took both your suggestions.  I put the folders into the Users\Public folder and I created them without checking for their existance.  It's working now.  Thanks.
(4,976 Views)
rickford66 wrote:It's working now.  Thanks.
The only proper thanks is a Kudo Smiley Wink
(4,966 Views)
Haha, no problem.
(4,964 Views)
