create own block in LabVIEW
Is it possible and how to create own block in LAbVIEW, where input for this block is a LabVIEW model?
Message 1 of 11
(7,419 Views)
What do you mean by block?
I expect that yo ucan do what you are asking but what you are asking does not have enough detail to answer your question. Eplain what a block is. What data it has. What model you are trying to use
Tim
GHSP
Message 2 of 11
(7,409 Views)
Do you mean sub vi's?  If so, take a look at this tutorial.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YK4VCAW&l=en-US
Message 3 of 11
(7,407 Views)
I mean a element (component), which could to use LabVIEW Block Diagram as Input and someone's way process it.
Message 4 of 11
(7,384 Views)
Learning material list under "Looking For Free Training":
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
Message 5 of 11
(7,383 Views)
You need to explain what you are trying to do. You have an element of what? (array, Cluster) We need more information.
Tim
GHSP
Message 6 of 11
(7,358 Views)
Sounds like you are referring to a subVI.  If you are struggling with this, I recommend taking some tutorials
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
Message 7 of 11
(7,344 Views)
I need a own element, in which in front panel i could create a block diagramm,  which this element can process. It is nessecary for create own compiler for projekt in LabVIEW.
I want to know, is it possible to create own such element in LabVIEW
Message 8 of 11
(7,333 Views)
" It is nessecary for create own compiler for projekt in LabVIEW."
sorry, I have still no idea what you are asking for? Can you ask a friend or colleague with better English to detail the question further?
edit: hmm, "I need a own element, in which in front panel i could create a block diagramm,  "
Do you mean, you would like to make a VI, where during runtime, you could create a kind of block diagram on the front panel?
edit: if this is what you want, I guess it can be possible via scripting, but I am not familiar with this topic...
https://www.ni.com/en/support/downloads/tools-network/download.labview-vi-scripting.html
https://www.youtube.com/watch?v=vB78FFxRm3A
Message 9 of 11
(7,312 Views)
No it isn't.  Scripting does not work on a VI that is running.
Maybe the OP is talking about XControls?
Message 10 of 11
(7,282 Views)
