create password to my application, is possible?
I attached the executable file, i put the file saved on c:.
I could too, get the directory of windows\system and save there...
In the key screen, I put the correct key (down) about the serial hhd. So you can test it, working.
And you can see like the value is possible calculated having the generates and entry keys!.
That's why i would like rotate the digits.!.
Message 21 of 22
(590 Views)
Hello Fonsi;
I am reproducing here some of my thoughts from another discussion:
If you still want to implement the copyright scheme yourself, this are some of my thoughts about that subject. I hope this can start a good topic of conversation:
If you want your program to run on a specific machine, you need to know about that machine so your software is somehow "made" exclusively for that machine. If you can make the software so it utilize resources very specific to the target computer, then you are ok. It is difficult to come up with the right analogy. Let say it is like somebody make a uniform specifically for you and take into consideration all your exact measurements like size, weight, etc. (we are assuming a little here, like those measurement won't change). It can be argued that there maybe somebody in the universe that is like you, but the chances can be sufficiently low so it is acceptable to you to take the risk. All this is usually very difficult and expensive.
A more common approach is to know information that can uniquely identify the computer and then create the application so it first ask the computer to identify itself. Upon correct identification, the application provide its services. An analogy is that I am the one who provide the services and I have your name and driver license number on file. If you request service, I ask you for those identifiers and once I verify your identity you are good to go.
A more secure approach will be that we share a secret like a password. I, as the application, ask you (the computer) to authenticate, that is, to provide identification and the password. An alternative is to have something that, although is not secret, it cannot be forged (at least, within certain probability). Let say I ask you for your signature. The bundle human presence + signature cannot be forged.
A way to implement the latest one may go like the following: each copy of your software has a unique identifier (SI) and a unique key (K) that enable the application. You ask the target computer for its unique identifiers (CUI). You generate a random string (R) for the secret and then create a function f such that: K = f(SI, CUI, R). To get the right key K that enable your software, all the other parameters must be the right ones.
If this is done right, the security of the application will depend on the secret (R), so you better generate and manage R right. Also, you want to make sure the function f() cannot be bypassed (i.e., direct insertion of K is not possible).
Regards;
Enrique
www.vartortech.com
Message 22 of 22
(577 Views)
