create pdf report LV 2015
Hello everybody,
I need to create programatically report in pdf from a VI,
I downloaded the PDF TOOLKIT from https://www.ni.com/en/support/downloads/tools-network/download.pdf-toolkit-for-labview.html
But when i try to open the "Vi installer" it gives me error (attached here).
Do you know why isn0t running whith LV 2015?
Do you know another toolkit running with it?
(4,458 Views)
You could also try:
1) Word or Excel report (from Report Generation Toolkit) with https://forums.ni.com/t5/Example-Code/Save-Word-or-Excel-report-as-a-PDF-using-Report-Generation/ta-...
2) Simplicity AI PDF Generator https://www.simplicityai.com/custom-pdf-generator/
3)  PDF Report with iTextSharp https://forums.ni.com/t5/Example-Code/PDF-Report-with-ItextSharp/ta-p/3500858#%2F
(4,433 Views)
Did you read the reviews of the PDF Toolkit?  Does not sound like a robust (= working) product ...
Bob Schor
(4,410 Views)
I installed the PDF Report and it seems to work
Thanks a lot.
Now i just have to figure it out HOW it works
(4,335 Views)
