create project programmable
I would like to create a project programmable. It’s easy to inserts files in the project and refreshes the dependencies, but when I want to setup “application build” and “installer build” programmable it becomes difficult. Anybody out there who have some examples?
(2,951 Views)
What do you mean by the term "programmable"?
(2,916 Views)
A LabView program which inserts VI’s, support files, set destination, version and name in a project. VI-Server can be used for that. My problem is that the data structure for the application build and installer build scripts is a totally flat structure and it hasn’t been possible to find any documentation.
(2,911 Views)
You might wish to check out the OpenG builder, which should show you how to do this.
___________________
Try to take over the world!
(2,897 Views)
