create shared variable
hello,
1) I want to use shared variable in my project.i want to pass array to a vi on other machin.m using network shared variable.but the problem is tha  it sometimes shows the value and next time when i run vi,it does not.i dont know what happens.
2)how to add RT in project explorer? i have attatched a bmp file which will tell what do i meant by RT.
3)if somone can tell me steps in DETAIL about how to create shared variable properly,with example..then please help me out.
Thak you
gak
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,981 Views)
Accepted by topic author Gak
Hello gak.
You should have a look at NI Developer Zone. I think you will find what you want.
I give you this link to begin.
Regards.
Romain D.
National Instruments France
(2,956 Views)
