create shortcut folder in desktop
Hi Guru,
I understand what Hu Yu wants to say.
But currently i have c drive only. So i cant create a shortcut at the same folder . I want to direct my .Ink file to desktop. To send to the desktop the link can't send as we did create folder in other driver such as example tht Hu Yu given.
Please guide me how to do link the .Ink to desktop not to other drive.
Please help thank you.
Message 11 of 30
(3,185 Views)
So this is the true problem.
You can use some specified characters to locate desktop
the following example create a shortcut  Win.lnk on the Desktop which point to the  C:\Windows folder
shortcut /f:"%USERPROFILE%\Desktop\Win.lnk" /a:c /t:C:\Windows
Best Regards
Hu Yu
Message 12 of 30
(3,180 Views)
If windows XP is installed in the PC then the Path of the desktop could be "C:\Documents and Settings\XXX\Desktop"
here "XXX" is the username.
you can get the information regarding the current logged in user through some user32.dll (i guess) and can create the above path.
Just give it a try once.
Also there might be chance that the LV application which creates this shortcut file on the dektop for a certain user might not have the "write" permission and you may fail. Check for these and do reply in case you are sucesful
Message Edited by Guruthilak on 02-02-2010 11:20 AM
Regards
Guru (CLA)
Message 13 of 30
(3,173 Views)
I have tried this but it says..shortcut is not recognized..i have attached the testing i made..please help.thank you
Message 14 of 30
(3,162 Views)
You can
DOWNLOAD the shortcut.exe form here,
copy the shortcut.exe to C:\Documents and Settings\Administrator\
then run the command at C:\Documents and Settings\Administrator\    path
And Note:
thats Win.lnk(short for link), not ink
Message Edited by NIhuyu on 02-01-2010 10:47 PM
Message Edited by NIhuyu on 02-01-2010 10:48 PM
Best Regards
Hu Yu
Message 15 of 30
(3,157 Views)
Im sorry again Hu Yu,
How to run the command ? so i can get C:\Documents and Settings\Administrator\    path
sorry im really dumb in this dos commands. Please help thank you
Message 16 of 30
(3,149 Views)
Under CMD
Use C: to change to disk C
Use cd <folder name> to change to the specified folder
You may pay attention to the underlined path, that's your current working path, you just make sure the current working path is the same as you shortcut.exe's path, that should work
Best Regards
Hu Yu
Message 17 of 30
(3,144 Views)
Is there a chance that %USERPROFILE%\Desktop is called something else in non English Windows versions????
Rolf Kalbermatter  My Blog
Message 18 of 30
(3,142 Views)
I gave that a try on Windows XP Chinese version.
It works. But I don't know the result for other languages of Windows XP.
Best Regards
Hu Yu
Message 19 of 30
(3,138 Views)
Its works..Thank you Hu Yu.
So if i wana do in labview 8.0, is it i need to run each command one by one till the last ?
Message 20 of 30
(3,135 Views)
