create system image.vi error localhost
Hi!
I have labview 2013 and I am trying to generate an image of all software installed in my computer.
I have tried with the simple code attached but an error pops up. Do you have any sugestion how to generete that kind of image? I will have to generate an image of the localhost computer and later also of the the remote computer (pxi system).
Thanks in advance.
Pablo
(3,467 Views)
As far as I know, the 'create system image' VI is for remote targets like CompactRIOs (i.e. where you install an NI software set to the target). I don't think you can create an image of a desktop setup with it.
I think the closest you can get is to export a software configuration which will tell you what software and version you have installed on your PC (like you get with the NI MAX configuration report).
(blog)
(3,459 Views)
