create trial vi
How can I create a trial vi. i.e it expires after some runs or days..
(3,200 Views)
You need to put a date-checker code inside your VI as the first task. Check for some maximum date to make it able to be run. If this date is crossed, just popup a dialog msg to the user & stop the VI & go out.
Or else, you can write the current date & time of the first run of the VI to an INI file under the header [First Run].
Then compare the current date & time of the subsequent run(s) of the VI with this [First Run] data from the INI & allow the VI to be run or not, based on the comparison of these dates upto a certain predetermined no. of days, inside your VI.
- Partha ( CLD until Oct 2027 🙂 )
(3,195 Views)
Hi visa serial re...,
see these results please.
Mike
(3,179 Views)
