create vi-internal switch
I need to create a switch that is manipulated not by the user but by the vi itself. More precisely, I need an element, that is always "true" until it receives a "true" from another structure running in parallel.
The problem with all the comparing elements is, that they wait for both signals. But in my case, I cant wait for the slower loop...
I hope you undestand my problem despite my weak english.
Greets from Germany
Karin
(2,864 Views)
If I understood you correctly, than you could use internal variables (see VI attached). If thats not what you wanted, tell me (eix at itiv.uni-karlsruhe.de).
Ilos
(2,864 Views)
Hi Karin,
You may want to use a case structure.
That will allow you determine which of the two loops will execute.
Otherwise,
Post in German!
Some of best Enthusiast speak German.
We are big, we are bad, we are international!
Ben
(2,864 Views)
