createCDATAsection with MSXML in LabView?
Hi everybody,
I have a problem using MSXML DOM in LabVIEW. After I have created a CDATA node filled with Data, I can't append this node as a child node to a parent node.
MSDN provides a solution in Visual Basic:
Dim xmlDoc As New Msxml2.DOMDocument30
Dim root As IXMLDOMElement
Dim CDATASection As IXMLDOMCDATASection
xmlDoc.async = False
xmlDoc.loadXML "<root><child/></root>"
If (xmlDoc.parseError.errorCode <> 0) Then
   Dim myErr
   Set myErr = xmlDoc.parseError
   MsgBox("You have error " & myErr.reason)
Else
   Set root = xmlDoc.documentElement
   Set CDATASection = xmlDoc.createCDATASection("Hello World!")
   root.appendChild CDATASection
   MsgBox (root.xml)
End If
How can I transfer this solution is LabVIEW? When I try this, I cannot use the output of the createCDATAsection as input for the appendchild method.
Any help would be appriciated. I google'd and searched this forim without success.
(3,520 Views)
try it with a typecast like in my attached example.
regards
Marco Brauner NIG
(3,512 Views)
Hi Marco,
thanks for this solution, it looks very interesting. However, meanwhile I have found another way for this problem:
First you should create the parentNode as a normal NODE_ELEMENT. After that create a Node as NODE_CDATA_SECTION and append it as a childnode. Now we can use the simple text property to write the data formatted in CDATA.
I have attached the solution.
Anyway I will test your solution, because it looks very interesting 🙂
(3,501 Views)
