creating AVI
Hi all,
           I am having a recorded AVI file in which I want to add text as a overlay at particular position. I was able to add the overlay at particular position on a particular frames. But I don't know how to write all this as a new AVI.
Having LabVIEW and VISION 7.0
Any help greatly appreciated.
Prasath.
Prasath M,
Emmeskay Systems Solutions Pvt. Ltd.
No: 20, Kannadasan Salai,
Chennai - 600 017.
mprasath@hotmail.com
(3,067 Views)
Prasath,
You will have to use the IMAQ Merge Overlay.vi to destructivley add your overlays to the image data - this can then be written to an AVI. Overlays are not actually a part of the image and do not change the image data until a merge is called. AVI's do not have the ability to save overlay data - only image data, so a destructive merge must be done to permanently make the overlay part of the image.
This link give a few more example of using overlays:
[broken link removed; example no longer available]
Hopefully this puts you on the right track.
(3,037 Views)
Thank you very much for your reply. I will do that.
Prasath.
Prasath M,
Chennai - 600 017.
(3,028 Views)
