creating a data simulator and geting an error i cant figur out
I am new to labview and i am using labview 7.1 student version. I am creating a data simulator and geting an error in my for loop. I have attached my program. if someone  can help it would be appreciated.
(2,838 Views)
The error message says 'integer type required". You are doing a bit exclusive or with "X^4" and that requires you to make X an integer. If you did not intend to do the bit exclusive or, what did you really want to do?
(2,831 Views)
Hi marcv,
      When I open your VI it's broken and the error seems related to this term in a formula node:
Y=5*X^4  (The ^ function wants an integer, but X is a float)
To raise X to the 4th, try:
Y=5*pow(X,4)
Cheers.
Message Edited by Dynamik on 04-15-2006 07:06 PM
Message Edited by Dynamik on 04-15-2006 07:10 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
(2,830 Views)
thanx Dynamic that woks.Smiley Very Happy
(2,821 Views)
