creating a scale
i am building an xy graph.
i have my y-data wired.
i want my x data to be in 0.05 mm increments.
how can i do this?
(2,680 Views)
The x-axis of an XY Graph is whatever your x array is. If you don't have an x array and just want to plot evenly spaced data, you should be using a normal graph. Just set the multiplier to .05 (Properties>Scales).
(2,676 Views)
