creating a square wave
using mathematical formula without using square wave function. Is it possible?
Message 1 of 8
(4,518 Views)
@Alphasmsn wrote:
Is it possible?
Yes.
What I usually do is use a boolean that I toggle every so often.  I then use the Boolean to (0,1) function and multiply by the desired amplitude.
Message 2 of 8
(4,514 Views)
I want to automatically generate square wave without manually toggle it.
Message 3 of 8
(4,510 Views)
Who said anything about manual operation?  Setup a loop.  Every so many iterations, you toggle the boolean.  If you toggle every iteration, it looks like a triangle wave.  But it should be a good start for you.
Message 4 of 8
(4,503 Views)
I am new to Labview so I have no idea how to generate using booleen.
The vi shown generate a triangle waveform, but how can I convert it to a square wave?
Message 5 of 8
(4,472 Views)
Hi Alpha,
simply change the plot settings in the VI shown above and you're done 😄
Message 6 of 8
(4,463 Views)
Yes, I told you that would be a triangle wave.  I also told you that you need to create code to toggle only every X number of iterations.  Think it through.  You can figure this out.  Post back with what code you have tried and what it isn't doing that you want it to.
Message 7 of 8
(4,441 Views)
screenshot attached
Message 8 of 8
(4,398 Views)
