creating a temporary value
hi all,
i am trying to create a temporary value for a timestamp so that i can calculate the time difference between timestamps.  i was wondering if anyone knew a way to temporarily store a value aka the previous timestamp so that  i can simply subtract the difference between the current and previous times. thank you
Message 1 of 8
(4,645 Views)
What you want to do is use a shift register.  The shift register will allow you to store the value and pass it around the loop for the next iteration.  You can change a loop tunnel to a shift register by right-clicking and selecting "Change to shift register".  Check out the example VI attached.
Message 2 of 8
(4,639 Views)
thanks endmile
i ran the vi and it worked for the most part.  i was just wondering if the set time difference ever worked for you? or how i could make it work...
Message 3 of 8
(4,627 Views)
nvm.  sry im an idiot
Message 4 of 8
(4,622 Views)
No problem.  Glad I could help.
Message 5 of 8
(4,614 Views)
turns out that a shift register will suffice. does anybody know a way of creating a temporary variable within a loop that can be used for the next iteration?
Message 6 of 8
(4,604 Views)
and by will suffice i really meant wil NOT suffice
yup
Message 7 of 8
(4,590 Views)
Yes, it's called a shift register.
What exactly are you having a problem with? You just said that the shift register will suffice! Maybe if you posted the code you've written, someone can look at it.
Message 8 of 8
(4,589 Views)
