creating application icon
Can we import an image (etc png) for icons to use in icon editor to change labview default icon from icons in build specification?
Kind Regards
Austin
Message 1 of 9
(4,684 Views)
Hi Austin,
As per my knowledge, of course you can import an image for using it as an icon. The only constrain is you must have a .ico file for using as an image icon.
Warm Regards,
NitzZ
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved;))
Message 2 of 9
(4,677 Views)
You could also simply copy the image and paste it direcly into the Icon Editor.
Message 3 of 9
(4,663 Views)
The issue with importing a picture directly is the size of the picture since an icon is usually 16X16, 32X32 or 48X48. If you copy directly you will only see a portion of your picture. An easy run around is to use a free converter you can download from the web to convert your pictures to icon. Personally I use EasyPicture2Icon. You can then modify the result with the icon editor.
Ben64
Message 4 of 9
(4,662 Views)
I was working under the assumption that the OP had a PNG of an image of the appropriate size, such as the plethora of icons that you can find on sites like gettyicons.com, iconarchive.com, or openiconlibrary.sourceforge.net, and not a visage like this: http://wall.alphacoders.com/big.php?i=140520&w=2560&h=1600
Message 5 of 9
(4,659 Views)
How I change the size for icon to change it with another?
Message 6 of 9
(4,610 Views)
Please be more clear.
Message 7 of 9
(4,596 Views)
When I create icon the size of it go more from 48x48,
how can I create icon with the size of 48x48
Thank you very much
Sameera
Message 8 of 9
(4,564 Views)
Use IcoFX to make the icon. It's free and can create larger icons. Then, point LV to the .ico file you created.
___________________
Try to take over the world!
Message 9 of 9
(4,559 Views)
