creating calendar vi
I want to use a calendar that looks just like the one windows have when you click the clock on the screen.
Is there a ready VI in labview with a calendar?
Tzviel
Message 1 of 9
(6,160 Views)
Hi
There's a control name "Time Stamp Control". It includes a button which causes a calendar to appear if it is clicked.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 9
(6,153 Views)
If you are using some older version of LV then make use of the ActiveX control of calender
Message 3 of 9
(6,151 Views)
I have used the time stamp control.
How can I disable the seconds (work only with hours and minutes)?,on the numeric display I just changed the precision but when you press the calendar button to choose a date it shows the clendar with the seconds.
Message 4 of 9
(6,148 Views)
On the calendar unfortunately you can't change the format.
Using LV8.0
Message 5 of 9
(6,146 Views)
Put an activex control on your front panel. Right click on the control and insert an activex object. My computer had a Microsoft Date&Time picker control and a Microsoft MonthView control.
Message 6 of 9
(6,133 Views)
looks great-this was just what I was looking for.
how can I extract from the ActiveX the date and time as a string??
tzviel
Message 7 of 9
(6,130 Views)
Wire the terminal (which is an activeX reference) to a property node. Select the property "value" and use the variant to data-function to convert it to a string.
Hope this helps.
Thomas
Using LV8.0
Message 8 of 9
(6,125 Views)
There is also a labview function that takes a cluster of data and makes it a timestamp. Date/Time to Seconds is under the Time&Dialog section.
Message 9 of 9
(6,115 Views)
