creating installer without Distrubution of MAX
I am creating installer but with it MAX shortcut is getting loaded on desktop.How to avoid MAX on desktop while creating installer using LABVIEW 8.5?
(2,332 Views)
When you create the installer, select to export the MAX configuration so that will be included in your installer and exclude MAX as part of the installer. You should find this in additional installer options while building.
Message Edited by muks on 02-22-2010 04:07 PM
(2,306 Views)
