creating listbox
I want to type multiple items into my listbox, but for some reason, after i pressed the key, the listbox will not let me type in the second item. Thanks.
(3,483 Views)
Are you using the carriage return on the keyboard above the shift? It won't work if you use execute (the enter on the numeric keypad).
2006 Ultimate LabVIEW G-eek.
(3,483 Views)
Yes, I am using the key above the . When I pressed , it just highlights the item that I just enter and won't let me put in another item.
(3,483 Views)
Try as I might, I can't duplicate this error. You could do one or both of the following:
1. Open a new vi, put in a fresh listbox and see if the error occurs.
2. Upload an example vi w/ a listbox that displays the error.
(3,483 Views)
Try Ctrl-Enter.
"analog" wrote in message
news:506500000008000000DEAB0000-1066448259000@exchange.ni.com...
(3,483 Views)
It's still the same when I open a new VI with a new listbox. However, if I upload an example with 5 item in the listbox, then I can change the 5 items in the example listbox; guess I will just have to do it this way.
(3,483 Views)
