creating multiple graphs from different channels
I'm trying to view different graphs on the front panel, so that each channel has its own graph.
(2,640 Views)
Assuming that you're using DAQ to acquire some channels, then you've either got a 2D array of numbers, or a 1D array of waveform data types. In either case, you use the Index Array function to select the channels and separate them for the different indicators.
(2,640 Views)
