01-02-2013 06:00 PM
I have array of clusters
In cluster I have image, xy plot and some integer values
I want to create table report, one cluster per row
I ve seen examples but just cant safe this images..
Any suggestions??
Solved! Go to Solution.
01-03-2013 02:45 AM
Hello Pawhan,
Use the reference of your cluster and pass this cluster reference to append control image to report function under report generation pallet.
Same procedure you can use to print any graph chart individually in report.
07-15-2013 04:08 AM
Have you ever tried to work it out with the hlp of some professional PDF SDKs?
As for myself, I used to creat report to pdf with the help of another PDF SDK. It is just one of many but I do appreciate its simple way of processing. Even though I only tried its free trial package to creat report to pdf and didn′t check the cost and licensing conditions, it works great for me. I hope you success. Good luck.
