creating three out of phase signals
Id like to create three to 4 out of phase signals.
This is in the range of 100Hz with 500-1000 samples per channel.
The signal can be digital or analog at 5V
What is the best way to do this.
How about with a 6601?
Anyone have any ideas
(2,402 Views)
Normally the way this works is that you generate the waveforms algorithmically and then write them to some type of IO. What part of that are you having trouble with?
Mike ...
Certified LabVIEW Architect
LabVIEW Champion
(2,381 Views)
the problem was that its difficult to have three very perfect out of phase signals
we the phase changes when you change frequency
there is some lag
we got it working good enough for now
so thanks anyway
(2,366 Views)
