creating z matrix for 3D graph
hello there,
i am generating a scan using an XY table with a sensor mounted i.e. the z component. i want to run these coordinates to a 3D surface graph. i have all the x,y and z individual values but i dont know how to convert these to a z matrix required for the graph. Has anybody come across this problem before?
I have attached the relevant file
Dave
(2,941 Views)
Hi Dave
As I understand you want to plot a surface defined by your x,y and z arrays. Take a look at the following thread which provides a demo on plotting a mesh which is a surface defined by a set of x,y and z points.
http://forums.ni.com/ni/board/message?board.id=170&message.id=114622#M114622
I hope this helps
Message Edited by SciWare on 05-16-2005 06:39 AM
Kurt Friday
www.sciware.com.au
(2,936 Views)
