crio 9068
I'm working with CRIO 9068. I'm trying to configure CRIO in MAX (to change ip, install software...) but status led blinks twice every few seconds. I can't put chassis in safe mod (I tried) because ststus led always blinks twice (it should be three times in safe mode).
Any suggestions?
(3,466 Views)
The LED blinking twice means that there's a software error. It is probably due to a bad install (interrupted somehow or. Try the following :
- Hit the reset button for 10 seconds
- Formatting and reinstalling the cRIO with the latest driver versions
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(3,448 Views)
How could I format cRIO?
I thin I need administrator password for that?
Thanks!
(3,438 Views)
Dear Blaza,
indeed the security features of the 9068 controller make it necessary to log in for formatting, software updates, restarts, etc. Here you can find some additional information.
Kind regards:
Andrew Valko
National Instruments Hungary
(3,373 Views)
