crio serial port
Hi nehap,
start a new thread for your different problem!
Message 11 of 20
(3,954 Views)
I am using serial port of cRIO 9076 as input, I used serial communication program to take the input and write it to a file. Initially with direct conncetion of RS232 cable to my PC the program worked well and I could save the data in a text file. Now that I am trying to save data via crio serial port, I am not able to get any data in my text file. Pls help.
Is there  any additional block i need to add for the sake of serial communication through crio.
Message 12 of 20
(3,928 Views)
Hi nehap,
Which "program" do you use? Can you attach your VI?
Do you get any errors?
You said the issue was solved!?
How are you saveing the data?
Where are you saving that data? (Which file path do you use?)
How is this related to your last comment of using AO/DIO with your cRIO?
Message 13 of 20
(3,924 Views)
@GerdW wrote:
Hi nehap,
this is the VI image. Pls help.
Message 14 of 20
(3,911 Views)
Hi nehap,
How can we help with an image of the VI?
Does the car repair shop help when you provide them with an image of your car???
On this image:
- when there is a VISA error you will NOT save any data to your file
- there is no check for VISA errors visible
- you can resize the IndexArray function to provide more than just one output and so greatly simplify your VI
- which file path do you use for saving data? Do you know your cRIO CANNOT save to your PC's harddrive!?
Message 15 of 20
(3,905 Views)
Why are you being so rude? First of all, I am so stuck in my problems. If you are not willing to help, say so, don't be mean.
Message 16 of 20
(3,904 Views)
Hi nehap,
where have I been rude? I just told you we cannot help you (much) by looking at images…
I asked specific questions to be able to help you.
Either answer those questions or attach your VI (with useful default settings in all controls) to get more help!
Message 17 of 20
(3,899 Views)
because you cannot read!
also (at least in my book) you did failed every etiquette of forum usage.
(digging up old posts from their graves without contributing anything, but just "me too",
not starting a new thread for a completely different question, ...)
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 18 of 20
(3,895 Views)
yes, you are right. When I started a new thread I did not get any reply.
Message 19 of 20
(3,878 Views)
Discussion continues here!
Message 20 of 20
(3,873 Views)
