crio
Hi every one,
                       i am using crio 9025 Cont , 9113 Chass and 9403(digital module) for frequency measurement. i have a problem  when i was measuring  low frequency i.e 0Hz to 1Hz.
(3,078 Views)
What do you think, how are you planning to precede?
Christian
(3,076 Views)
Jumping of signal is happeningwhile there is change in frequencyand it becomes stable after one iteration.
for example if frequency change from 0.1Hz to 0.5Hz,there is 0.3Hz in betweeen .
0.1,0.1,0.3,0.5 ,0.5
(3,063 Views)
