cross correlation between two signals with time delay
Hi everyone
I am new to labview and the forum so I apologies in advance. I am trying to-do a cross correlation between two "live/continues" signals with time delay on one of the signals. At the moment I am using a function generator to create one (sin) signal, splitting the signal and delaying one path (this part I have done). But I have tried using the C-correlation express, C-correlation PtByPt, both correlation and convolution Vi’s but can’t get it to work. Is there something that I should be doing before or to the functions themselves. The graph i get is more of a "beat" graph when i believe it should look more like a repeated connected Gaussian. I have attached the VI and an image of my file. Thanks for the help.
(2,991 Views)
Do the math.  The cross-correlation of a sinusoid and a delayed version of the same sinusoid should look like the cosine of the delay (or "just another sinusoid").  Sadly, Gauss has nothing to do with it.
Bob Schor
(2,968 Views)
