cross-correlation
Hi
I am using LabView 7.1.
I am doing the cross-correlation of 2 signals. The y-axis is pressure amplitude.
I used Read LVM to feed the saved signals to the cross-correlation vi as shown in attachment.
The chart shows the correlation value from 0 to 6. However I think it should come in the range from -1 to +1.
I will highly appreciate for any suggestions over this problem.
(5,893 Views)
hi!
   what you refer to is normalized, while cross-correlation function can return any number, also infinite (think about 2 constant functions).
graziano
(5,887 Views)
hi graziano
Thanks for your reply.
Did you mean to say to normalize the signal by dividing by sqrt(x*y)?
Am I using the correct way to find the cross correlation function?
Pramod
(5,880 Views)
Hi!
   I don't know how this function can be normalized, though I suppose there's a way, but I suppose it is more complicate than you said....
   I think you're calculating cross-correlation the right way, the function is quite simple....
graziano
(5,878 Views)
Pramod,
I'm in a similar situation right now. I'm looking for +1 to -1 values...did you determine what the solution was?
T
Tyler C. | Certified LabVIEW Associate Developer
(5,496 Views)
Hi pbsalunkhe,
A popular definition for the Normalized Cross-Correlation is:
sum(A(i)B(i))/sqrt(sum(A(i)^2) sum(B(i)^2))
A & B are the two signals you would like to calculate. Hope this helps.
Message Edited by strong@ni on 09-17-2009 04:57 AM
Message Edited by strong@ni on 09-17-2009 04:58 AM
(5,473 Views)
That formula only works if the local mean and standard deviation of the signal is constant.  The best reference for Fast Normalized Correlation is:
J. P. Lewis  Fast Normalized Cross-Correlation. Vision Interface 1995. (PDF)
See also this thread which relates to 2D cross-correlation, but the same code I wrote is easily modified for 1D NCC.
Cheers ~ Greg
(5,454 Views)
