cross power
Hi can anyone advise me how to create the cross spectral density in Labview.
(3,859 Views)
I posted some info here
Steve Bird
Culverson.com
LinkedIn
(3,838 Views)
Hi, Thanks for your reply. I have read through it.
1.I am looking for the cross power density which is in the normalised form as the PSD.
Do you think i can create the CSD by using the cross power divide by the frequency resolution?
2. I did an test i use the FFT.vi,  the FFT Power spectrum.vi and the PSD.vi on an signal.
Result obtained,i was able to verify between the FFT and the FFT Power spectrum but i could not verify the PSD answer.
PSD= power spectrum in Vrms^2 / freq resolution * noise power bandwidth of window
how do i adjust the noise power bandwidth of window?
(3,828 Views)
Alas, I am not qualified to answer those questions.
I'm not sure what the "bandwidth" of a window is. The window function you use operates on a timewave. It has an amplitude factor associated with it (Hanning = 0.5, FlatTop = 0.281, etc.) . But AFAIK, it doesn't have a "bandwidth" number.
The term "normalized" would mean to me that the spectral peak (highest amplitude magnitude) is multiplied by some factor X to make it 1.0. All the other spectral bins would then be multiplied by this same X and would thuse come out as some number between 0 and 1.
These are reasonably educated guesses, but guesses nonetheless.
Steve Bird
Culverson.com
LinkedIn
(3,822 Views)
Say can you demostrate how would you calculate the coherence between two signals using the FFT power spectrum.vi and cross spectrum.vi?
(3,818 Views)
See the link I posted above. It does just that.
Steve Bird
Culverson.com
LinkedIn
(3,814 Views)
